Post by MarkM22 on Jan 9, 2022 7:44:05 GMT -6
Does the hydraulic fluid get poured into the open pipe sticking up behind the seat?
Post by Admin on Jan 10, 2022 14:27:04 GMT -6
To the Right of the Top Link Base is the Hydraulic Fill Port. Make sure you are truly low before adding. Need to be on level ground. Hydraulic Fluid is very clear and can be hard to confirm it's low. One tip is to point the tractor down hill to confirm it's low as the oil will run to the front of the system where you can be assured it's low. Do not want to overfill the hydraulic system.
