Post by Admin on Oct 23, 2021 9:01:48 GMT -6
They may look the same on the outside but what's inside makes the difference and your tractor knows it. Your Tractor's Electrical System works with many components to help get you started and supplying power all day long. - Batteries: it all starts here. Have the correct Cold Cranking Amp and Reserve Capacity will get you started. Low Batteries reduce the Starter Performance. - Starter: Draggy or Worn Starters require more power to get your engine started. Your Starter is matched to the battery to provide reliable starts time after time. - Alternator: Once you start the tractor the Alternator replenishes the battery "Juice" that was used to start the tractor. Just like a Bank Account you take money out to get starter but the Alternator must put the money back in. Plus the alternator maintains enough power to run all the cool features of your tractor the more tools you have the more juice you need. Keeping them working together will increase your performance and reduce your downtime. Insists on Genuine AGCO Parts the Original Equipment Parts for all you Parts Needs
