Post by Admin on Jun 11, 2016 12:15:34 GMT -6
The Wait is Over for West Central Missouri...we just received our First 4700 Global Series Tractor and here is some Walk-Around and Feature Discussions we complete. Tune in for even more footage coming real soon!
Deluxe Package Upgrade: 12x12 Transmission with Power Shuttle (6 gears, 2 ranges with declutch on main gear lever) * Telescopic Stabilizers * Lever Controlled 3-Point Linkage with Draft Control * External 3-Point Lift Control on Left Hand Side Fender * Hydralock Differential Lock * 2 Mechanically * Controlled Spool Valves (1 x DA KO FL + 1 x DA KO FL) * Digital & Analog Instrument Panel with Performance Monitor * Spring Suspension Seat with Armrests * 30 Amp Auxiliary Electrical Socket * Mid Mounted Work Lights * Rear Sided Fender Extensions * Fuel Tank Guard * Tilt Steering Column
